What's normal/low/high compression for a healthy ka motor
DRIFTEADOR
Before I buy it I want to make sure the motor can be boosted. So far I've seen 170psi with ~10% difference between cylinders. sound good? what were your numbers before boosted vs. now? I remember reading somewhere that one member's compression went up after boosted. probably from carbn build up from running rich.
nissanfanatic
Car: 1992 Nissan 240sx SE
Mine was:#1-190psi#2-190psi#3-185psi#4-180psi
After 1000 miles of boosting. 135000 miles on the engine. The tech specs are
Factory-179psiMinimum-151psiMaximum difference between cylinders-14psi
I think my high readings may have something to do with the synthetic oil. Who knows.
DRIFTEADOR
thanks. do you by chance know the specs for a sr? not really off topic, but probably not the correct forum to ask...
Structure240sx
factory SR compression readings is about 170psi IIRC. theres a chance its 165psi or 175psi. off the top of my head it is 170psi for a perfect motor
