what's needed/where to find
sd2nola
Car: 1993 240sx
hey this might be a dumb question but i need to know. can or are you supposed to tune the sr20det even if you are running stock boost and stock everything really? the only thing i have are a few bolt ons. if i do need to tune what all do i need and where can i find it?
Thanks!!!!
ILikeMy240sx
Car: SR Power
stock SRs with stock MAF and injectors dont really need a tune unless you are trying to squeeze out every little horsepower out of the stock setup. I think stock tune is pretty decent.
Anyways, if you do want to tune then there are many ways to do it.
1) Enthalpy or JWT Rom tune. Probably the easiest. Basically you tell them the mods you have and they tune it for you. Plug n Play.
2) Piggyback (SAFC or Greddy e-manage). You need to tune it with a wideband either on an open street or on the dyno. Dyno is the best option. Also you need to know what you are doing in terms of assigning fuel correction values.
3) Standalones (AEM EMS, Apexi PowerFC, FCON, etc etc). Gives you a complete control over all the engine parameters. The most expensive but will net you the best results assuming the guy who tunes your car is a good tuner.
sd2nola
Car: 1993 240sx
for the first option...do i need to send my ecu some place or what?
