silviasgp06 »
https://forums.nicoclub.com/silviasgp06-u61439.html
Fri Aug 21, 2009 6:30 am
I dont mean to be harsh but please do alot of reading on the stickies so you dont get lost while wiring.
But that being said I do not see anything cut that will be a hard to fix. There are a few files on here that show you how to convert the S-chasis lower harness to work, so the cut fuse box/lower you have will not effect you. I cant remember what that 5+ wire cut section you are showing hanging by your turbo is off the top of my head but if someone doesnt answer Ill be sure to check.
Its really easy but if your at all not sure with what you are doing, have someone else like CARL H do your harness. Hes in the stickies.
