forecast »
https://forums.nicoclub.com/forecast-u7026.html
Thu Dec 26, 2002 1:19 pm
When I rebuilt my Q engine I paid a lot of attention to the lifters since I had heard horror stories about lifter clatter.
From my examination I determined (of couse I could be wrong)
Imagine two guys holding a ladder over thier heads. One guy is the valve stem and the other the valve lifter. Suddenly a giant fist drops out the sky and hits the ladder (rocker arm) in the middle. One or both of the guys goes down. In the engine it's the valve stem that drops, opening a valve down below, letting gases rush where they need to rush.
Suddenly the fist disappears, actaully it raises up a few feet. The stem guy can stand back up! in fact he comes up so quickly (driven by both a spring and gasses in the cylinder) that ladder keeps going up after he stops. In this condition the next time the fist (cam on the cam shaft) comes down the ladder thunk against the valve stem guy and cause a tiny bit of wear. Over a few million reps the valve stems busted.
Worse, the valve stem isn't a constant length. As it gets hot it longer.
Enter the valve lifter hero. He is resistant to the cam and won't go down except under very high pressure. When the cam rolls away he keeps the rocker arm tight against the valve stem. When the valve stem is cold, he lifts a little higher, to always keep the rocker arm in contact with both the valve stem and the cam.
How does he do this. Different cars do it differently. Some cars have fixed adjusters (Honda Accord)
but the Q has hydrulic lifters. This a two piece telescoping unit. At it's full height it will actually force the valve open a hair even if the cam is not trying to lift a valve. The unit also rides on a bubble of oil. The Valve lifter can rise up in it's seat a hair (not much though, the act of moving up relases the pressure that lifted it so I imagine it floats a 10th of an inch above it's seat in most cases. Under high pressure situations (long valve stem) the telescoping action in the valve lifter colapses by venting oil from an internal high pressure oil chamber. When the situation cools down, the valve re-extends by an internal spring pressue and the lifter redraws oil into the high pressure chamber back through a one way check valve.
If for some reason the lifter loses oil pressure it may draw some air into the high pressure chamber. From then on the valve lifer will never work right again - it collapses too easily and rocker arm (the ladder) slaps against the valve stem, cam shaft or valve lifter. That slapping noise sounds like a loud tick
Other failures of the valve lifter are - it seizes in it's seat and doesn't get any cushioning from an oil pocket. The telescoping unit seizes (loud cold engine, but quiet hot). Or the high pressure chamber won't hold pressure, the unit collapses under any load (this isn't very loud by limits valve opening since the lifter is moving not the valve.
dan
