lofapoo »
https://forums.nicoclub.com/lofapoo-u12390.html
Fri Jul 22, 2005 7:39 pm
Alright, something wierd happened tonight, for the second time, although I wasn't there to witness it this time. Coming down a hill (although the first time it happened it was on a flat road) the RPMs rised suddenly, around 2k, and the brakes lost power. They did not COMPLETELY lose power, but the car was unable to completely stop, it slowed down to 5-10 MPH. So as someone is about to side-swipe us I pop the flashers to avoid looking like an ******* on the road. Now, this first happened after the e-brake light stopped turning off, even when the brake was deployed. I just checked under the console, and fiddling with the switch there was nothing I could do to make the light go off. Though the car was not turned on, I just turned the key in the ignition to ON so the lights would turn on to see if it would go away. I'm not sure if the lack of the light turning off has anything to do with the problem, but it only happened after the light stopped turning off. Now I love my baby, although she is not perfect mechanically. The VSS needs replacement, sounds like the valves are ticking or the lifters are tapping so I'm going to try to add some oil conditioner and throw in some 93 octane to make her a bit happier, her idle sometimes bounces around from 500 to around 900 every so often causing the headlights to dim and brighten as the idle jumps, the exhaust stinks perhaps the cat needs replacement, and worst of all it has an automatic transmission. Now I'm not sure if any of these of my baby's flaws could contribute to what happened tonight and once before, but it's not very comforting knowing that she likes to **** her pants like that sometimes.
I'm going to try reading the ECU codes to see if it senses a problem with the car, but until then I'd like to hear what my fellow NICOnauts have to say about some of the crap going on with my car.
Please help
