MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Thu Aug 11, 2005 7:03 am
JWT ECU programmed for '93 Ford Cobra MAFS (ECU takes care of all timing and fuel curve, obviously), 50 lb/hr top feed MSD fuel injectors, phat ka-t aluminum fuel rail, aeromotive adjustable fuel pressure regulator, walbro 255 lph fuel pump, ngk iridiums gapped to ~.028-.030 (forget which), aurora 8 mm plug wires, and base timing at 23 deg btdc (yeah, it sounds outrageously advanced, but not when you see some of the timing numbers the JWT ECU has...and I'm running 93 octane, a large, efficient intercooler, and alcohol injection to help with any possibility of detonation)
