trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Thu Jul 31, 2003 9:39 am
Powdercoating runs in the area of $75 a wheel last time I checked. Not to mention the cost of having tires removed and re-mounted. The time is really a non-issue, it isn't as if taking time to paint his wheels would prevent him from getting a second job. The logic here is pretty simple. If you are experienced with using that cheap spray paint stuff you can yield a fairly good result, I've worked for a detail company and a dealership, every professional I've seen has used wheel paint to touch up or re-finish work factory work, as long as they keep the color the same.
On another note, if you want to strip off the bad job you have on there, Home Depot sells an industrial paint stripper in a big orange metal can, it's a brush on, and will NUKE anything on the wheels. Be careful with it, don't get it on your hands, and be sure to keep it ventilated. Who knows, you may be left with a bright aluminum surface you can polish, I've seen it happen before..............
