there are other drag radials, ie. bf goodrich, etc....but NITTO's usually have group buys if you search around
http://www.groupbuycenter.com etc
I use lightweight 16" rims for my drag radials, like 11-12lbs each
i meant feather the throttle while letting the clutch out, dunno why i said that...
If you can slip the clutch out (if you dont have a iron clutch), it will help the launch (also limit the life of the clutch), dumping the clutch, as opposed to letting it out slow will cause the tires to break loose, slowing your 60ft time.
Its a trial and error process, takes practice to see what rpm is best to launch at (no way to know before you break something), and how slow or fast to let out the clutch, and feather throttle (dont just slam it to the floor) try to make the tires grab.
