silencer.1 wrote:Nitrogen is the only gas that would work other than normal air. Hydrogen and Helium are too small of atoms and would diffuse through the tire/valve into the air. Hydogen is also way too flamable. Every time you blew a tire it would set the car on fire. I don't know about you, but I don't want a hydrogen filled tire anywhere near my fuel tank... Also solidified or liquid hydrogen is hella hard to produce. Solidified hydrogen occurs so close to absolute zero that there is no way it could ever be used in an aplication like this.
I agree with your conclusion but have concerns about one of your points. Compared to the holes found in naturally porous rubber, the sizes of a nitrogen, hydrogen and helium atom are nearly equal. I promise you hydrogen or helium wont diffuse thru a tire.
hydrogen = Hinderburg, nuff said...Helium is pretty rare. I imagine it would be more expensive (than nitrogen) due to the procedures used to harvest it from natural gas and other sources.Nitrogen would be the best choice, but as someone said, air is about 70% nitrogen anyway, and I'd rather get air at a gas station for 2 quarters.And SoCalS14, methane is much heavier than air!
Modified by IWannaS15 at 4:50 PM 9/16/2004
