Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.html
Wed Sep 03, 2003 3:15 pm
Provided that the engine is not cammed, and that you tested the compression correctly... that is a bad number.
If the engine is cammed, and you failed to hold open the throttle when cranking then go and re-test the engine the proper way.
Cams will cause a lower static compression at 300 rpm.
