Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Dec 04, 2002 8:53 am
ALL V12, V10, V8 and V6 engines have leaking valve covers ......the angle of the heads vs flat at top on I4 and I6! Every brand, every make, from every country and every planet and star system have leaks...........some are worse some are better depending on oil change habits.
You didn't say if you have an active car [add 1 hour] or TCS [add 1.3 hours] or both [add 2 hours].
With our low labor rate of $68 per hour we charge 7 hours for the basic Q plus any increment for options [ up to 9 hours] + parts .
Sounds like a decent dealer price considering the cost of operating in SF/SJ, California.
Not exactly cost effective to drive roundtrip to Atlanta to save $250-$300.
This like chain guides/chains/plugs/under plenum hoses has a high labor vs low parts cost against the more normal 55% parts and 45% labor of most work.
The worst is transmission rebuilds where $100-$200 worth of soft parts require 15 hours to change......see why trannies are best rebuilt in factories [assembly lines] where you can train people and get them to work for $12-13/hr {rural Tennessee].
