RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Fri Feb 11, 2011 12:29 pm
I would do some searching in the RB forum, But I bet you wouldn't start making boost untill 4Kish, and maybe make good power at 6K or so.
A stock DET would rev out to 7800 with out too much trouble, but the DE has weaker valve springs.
You'd need a built motor of any degree to use that for more then taking up space in your engine bay.
----I just looked it up, and if you could max that turbo out its a 1200HP turbo on a gas engine. What is your Goal? A NA RB25DE could hold at 350RWHP, and RB25DET's can hold 550RWHP indefinitely but your going to need a build motor to use the HT60.
~Alex
