What RPM's
SonyPete
Hey Guys, What RPM's do you guys normally run upto on a daily basis. I know it jumps up a bit with turboing just wanted to know how much you guys think its okay to run on a daily basis.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
As soon as the oil is up to temp...redline.
...always in boost. ~7200rpm or so, JWT ECU and cams.
RPM's aren't bad for your KA, assuming you use good oil and have a properly tuned setup.
- Brian
toki
I double clutch at around 10,000rpm.
SonyPete
Ummm I asked a serious question so I was expecting serious answers toki.
I just wanted to know what kind of RPMs you guys push with the KA rod length to stroke ratio with boost.
Come on guys post some numbers, I'd like to hear what you guys run with boost.
SonyPete
Guess I'm not worthy of anyone's post huh?
sunnys14
Car: S14
6500 rpms if everything holds together.
hannibal
Car: Red Line to Glenmont
My NA KA really sees 5500+rpm. I dont race on a daily basis, so I have no need to spin the motor that fast.
If you want to drive around at 7000rpm for the hell of it, buy a Honda with VTEC.
SonyPete
Quote »If you want to drive around at 7000rpm for the hell of it, buy a Honda with VTEC.[/quote] Thats not fair to say IWannaS15 cause its always better to make your torque peak as high in the RPM range as you can, lets you use your gearing to maximum ability. By staying in gear longer while staying in your best part of your torque range you get the best work out of your stock gearing. So by using boost and a slightly bigger cam to move your torque range up actually puts your gearing to better use when racing someone.
Check this site out it explains in more detailhttp://www.geocities.com/Motor....html
Nismo_Freak
Car: 89 Nissan 240SX
9200 ... 10700 if I want it.
Jookmasta
redline if traffic permits lol. honestly i think i redline the car mostly when entering onto highways..................after that the urge subsides.
KATwo40
Car: 1993 240sx KA-T
According to the dyno...mine likes to shift around 5600rpm. However, sometimes it sees 7500 on the autoX course. Oh, that's boosting 10psi, 165k mi. I don't necessarily recommend it, but that's how it happens sometimes.
Chezedik
Car: 1991 Nissan 240sx
Hit it until the motor starts sounding weak, this will happen just before redline. That is as high as you want to go.
