Good luck with that.blacksrjdm wrote:Presently I am turning 0 RPM's.
Thanks Hai- great info to know!hai1206vn wrote:depends on what transmission u have. S13 SR ratios are all the same as KA, but S14 SR 5th is 0.838 (vs stock 5th 0.759)
So on KA / S13 SR transmission I get 69-70mph @ 3k rpm in 5th
Check this out. The numbers here are for KA/S13 SR:http://www.car-videos.net/tool...ulate
HAHA, and your sig says "sleep is a crutch used by the weak". Talk about an oxymoron.SirSilvia wrote:file this under another 2second google search, search "km to mph" honestly google now throws you that search before you even start to type "to" for christs sake.
BTW I'm doing 1RPM and that's turning over and going back to sleep
, when I had a GPS when It was pretty accurate. When my USDM tyte cluster showed 60, 80, 100, etc the GPS did too. Sold the GPS shortly after to pay for the crazy high heating bill.White Comet wrote:just use a gps to display the correct speed in mph and compare it against your cluster
