240SXer »
https://forums.nicoclub.com/240sxer-u1300.html
Fri Nov 05, 2004 7:16 am
I'm on Nitto drag radials.. Last time I raced I launched at 5500rpm (@11psi) and I spun stright though first gear, and I was on the limitor while the 03 cobra was walking away. Then I launched at about 4800rpm and I hooked right up (was even with him because the Stang was on ET Streets).
The launching depends on too many variables... Surface, boost, tires, tire pressure, outside temp, tire temp, turbo (mine spools high), etc. Just gotta feel your car out.
If you're on slicks you have to launch really high to keep it from boging, since it won't spin. On most radials you have to launch it high enough to keep it in the boost, but not so high that is just engulfs. It's pretty hard but you get used to it. Where you really make up time is your shifting.
