What resistance should the CA18DET injector resistor pack be?.....
datsunboy
Car: Datsuns
I seem to have misplaced my FSM when moving.....but I tested them...and they are all 6ohms at the moment.is that what it should be?
biosehnsucht
6 ohms it is.
I'm using a DSM resistor pack myself, which is also 6 ohms.
Instead of hacking a DSM connector to my CA harness, or a Nissan connector to my DSM pack, I snatched a DSM and Nissan pair of connectors at the junkyard and rewired/pinned them to go together and make a jumper harness from Nissan to DSM, so if I ever get a real Nissan pack in the future I can plug it in w/o the jumper harness, and if I ahve to change to another DSM, I can still use the harness. no future soldering required
float_6969
That is how I did the wiring on my car too! I didn't cut one wire that was on the 240sx harness. All the cutting and splicing I did was on the CA harness and most of it I made sub harnesses to connect the 2 together so I didn't have to hack much of the CA harness either.
