What replacement parts do I need when installing an LSD
johnnydread
Installing an OBX LSD into an R200. What parts do we need to replace (bearings, clips, gaskets, etc.) when doing this? I've heard bearings and circlips. Where do I get the circlips? I can't find these listed as a regular replacement part.
NathanBrazil
Car: 1991 S13 Hatch RB2XDET - CP Piston, Spool Rods, HKS HG, GT3076R - Nistune
1993 Welded-diff stock a** E36 325i
Is it a Helical or Viscous?
Either way, you will probably need a couple tools to make sure everything is between specs. Backlash, End Play etc...
Look it up online and I'm pretty sure there is a lot of info based on swapping diff assembly to different cases, specially for s chassis!
I found this thread, it might help a bit... No pics tho :(
http://zilvia.net/f/showthread.php?t=101109
Hope it helps and good luck!
