what rb26 do i have
rbs14kouki
Car: rb27det s14 / sr20det s14
hi ... i have a rb26dett and i would like to know what year it is or rater what model (r32 or r33) cause i need to know for my downpipe
-my block is gray and not black so i know it`s not a r34.
-my crank collar is not short but i cant say if it is stock or it as being change by a gyu in japan.
-my power steering pump is rater small compare to the r32 (hicas) still dont know if someone change it before i got the motor .like on that website-->
https://www.rhdjapan.com/home/...=1698
thanks in advance for your help
Ramius83
Car: 1995 240sx SE
Give us a picture of your engine eith the wiring harness on it. Also, a "closer" shot of the harness near the oil cap is preferred.
rbs14kouki
ok i will take a picture tonight . thanks
rbs14kouki
engine wiring harness:
transmission harness:
ecu:
dont know if the picture will work it`s the first time i post pictures
rbs14kouki
[IMG][/IMG] C:\Documents and Settings\po\Bureau\po\2007-04-29-1522-23\HPIM3158.JPG
gawdzilla
Car: none
rbs14kouki wrote:engine wiring harness:
http://C:DocumentsandSettings...4.JPG
http://C:DocumentsandSettings...6.JPG
ecu:
http://C:DocumentsandSettings...8.JPG
@ those links. you need to upload them off your machine before those will work. try using photobucket or something, then linking to photobucket.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
well there are two thing on an r33 rb26 that you can see thats different from the r32.first the r33 power steering pump only has one psi line coming off of it and the r32 has two psi lines coming off of it for the hicas.and the r33 has one grey plug by the fuel psi regulator by the front of the fuel rail and the r32 does not.
rbs14kouki
here is my car on a web site here in Canada :
http://rbs14.monchar.com/
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
if thats the original power steering pump off your rb26 and your stock crank has a good crank collar then you more then likely have an r33.
rbs14kouki
engien harness :
crank :
crank collar :
power steering pump :
hope this time it will work!!!
rbs14kouki
anyways thanks guys for your help .
i dont get how to put picture !?!
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
try http://www.photobucket.com and load the pictures up on there and then they should have links under the picture for you to paste up anywhere and the picture or picture link will go up.
rbs14kouki
i have uploaded my picture whit photobucket but it still does the same thing ... i do have to use the (share URL)???
rbs14kouki
[IMG][/IMG]
rbs14kouki
it work i was just using the wrong adress under the picture
rbs14kouki
wiring harness:
[IMG]IMG]http://i202.photobucket.com/albums/aa74 ... IM3155.jpg[/IMG][/IMG]
crank :
[IMG][/IMG][IMG][/IMG]
power steering pump:
gawdzilla
Car: none
looks like r33, but why are you so concerned about 32 vs. 33?
Ramius83
Car: 1995 240sx SE
More than likely, your engine is an R33 engine. If you look at that picture you took of the wiring harness, look to the left of the injector wiring loom. You will see a single gray plug coming out of the harness. That is prominent in R33 GTRs.....
