what range of plugs should i run?
White Comet
Car: fc, s13 and mazda6, Sierra
i've done some searching but haven't found anything conclusive. i'm running ngk 6s right now on a mostly stock s13 blacktop but with the new setup; gt30 turbo, bigger injectors, and hp goal of high 300s, im wondering which ngks would be the best, the 7s or the 8s and also what they should be gapped to. thank for your help.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
The 3 places I turn to when I need info that I can't find myself are Enjuku, FRSport, and CIP Motorsports...
Enjuku's site says:
* Heat Range 6 for stock turbo 8-12psi
* Heat Range 7 for upgraded turbo 13-15psi
* Heat Range 8 for upgraded turbo 16-20psi
* Heat Range 9 for upgraded turbo 21+psi
Gap should be .30
P.S. I went with 8s on my SR with 810cc injectors and a GT3071R My goal was anywhere over 350. Hopefully low 400s
White Comet
thanks man, 8s were what i was thinking but i wanted to get feedback from people who actually ran a similar setup
