Not offical just from discussions a Tire Society meetings.Side wall stiffness is much more linear with 51 psi tires as there is NOTHING [93%] other than air to support.
http://www.tiresociety.org/pdf...b.pdfh ... ai...e.htm
FYI:Table III-7Braking Distance (in feet) provided by GoodyearWet Stopping Distance (0.050” water depth) Surface Speed ............................17 psi 25 psi 29 psi 35 psi 40 psiMacadam 25 mph 32.4 30.8 29 27.4 25.9Macadam 45 mph 107.6 101 100.8 98.6 97.1Concrete 25 mph 47.4 48.2 48.2 48.0 47.7Concrete 45 mph 182.6 167.2 167.4 163.6 158.2
Obviously as you increase psi the contact patch area decreases and the presssure exterted increases to the road so higher psi improves wet braking distances and increase the speed at which hydroplanning begins.
That alone should be enough to mandate the higher psi.
In 2000 the average tire placard for cars listed 30 psi as the recommended pressure????????????????????? Causing a 10 foot extra stopping distance in rain from just 45 mph!
These things are secrets kept from the public, unless you are a tire guy and know where to look.
The funeral home and critical care homes depend on 40,000 deaths per year from auto impacts and the 1 million severe injuries.
If everyone drove on less than half worn PS2 [or equivalent] in Summer and REAL Ice tires in winter..............so many health care people would be looking for work.
