What problems can happen from ignoring the check engine light?
SILVER97LE
I have a Nissan pick up that has had the light on for 5 years and it has never missed a beat. My 97 240's light just came on. Is it mainly hurting the efficiency of the engine or am I actually going to cause harm to the car?
Hijacker
Car: '92 240sx Convertible
'94 F-150
generally the CEL comes on when a component of the EFI system begins to go out, or has failed completely. For example. You can get a CEL when the O2 sensor stops working, or if a plug comes undone from its connector.
What happens then is that the ECU will give you a code to tell you exactly what's causing the CEL to come on. It'll give you a series of flashing lights, which you can cross reference with a code list to tell you what's wrong.
corn322
Car: 1993 240sx
here's a step by step on how to read the codes:
http://www.240sx.org/faq/artic...h.htm
Ubernoober
It makes old people cry, dogs burst into flames, and kittens chase plutonium and cheese sandwiches...
corn322
Car: 1993 240sx
so the kittens are chasing plutonium and sandwiches at the same time?
masticatingcow
Car: 94 Mazda FD3S
corn322 wrote:so the kittens are chasing plutonium and sandwiches at the same time?
I think so. That's always been my experience, anyway.
