what plug should i run in my rb20det?
91coupeRB20DET
Car: 1991 Nissan 240sx COUPE rb20det
1997 Nissan 240sx vh45de
1991 Nissan 240sx sr20det black top
alright it looks like a few ppl is havin the same prob. but i need to know a good plug an the gap, this is my first nissan an i did the rb20det swap an i no nothing about them i jus need a few pointers, an plugs an gap would be a great start. thanks guys
smbonn2005
Car: 1991 Nissan 240SX SE
bcpr6es-11 NGK plug, already gapped to 1.1mm
if you are running more boost then you may want to think about just the regular bcpr6es which is gapped to 0.8mm
91coupeRB20DET
is the regular ngk at 0.8 good for stock boost too?
smbonn2005
there should be no need for it to be gapped smaller unless your are running a significant more amount of boost from stock
91coupeRB20DET
but will it run ok? because som1 already told me to get those plugs an i got the regular ones...
jrb92se
Car: 1989 Nissan S13 coupe
ngk iridium dont know the part number ut search yuoul find it just make sure ou gap them propely for you specific engine
smbonn2005
they should run ok, but you can always gap them out if it doesnt run too well.
i personally dont like running anything but coppers in nissan boosted engines. for some reason ive seen anything but coppers get eaten 9 times out of ten. And iridium plugs are pregapped in the package they are not supposed to be gapped as it ruins the tips
91coupeRB20DET
thanks guys for yalls help, ill be on here alot since this is my first boosted motor
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
bkr7e
ngk part number 4644
91coupeRB20DET
bcpr6es part number 2330 is doin real good on my stock rb20det thanks guys for yalls help
whoareu
Car: 1993 rb25det s2 240sx vert
i keep hearing to run the bcpr6es plugs, went to 5 diff locations and coulld not be found, so i went to my tuner Andrei who has quite a bit of experience with nissans in general at one point they had the highest output ka documented, and an 800 whp daily driven rb26 s14.5 its blue and youve probably seen it. anyways he said to run the bkpr6es, mine isnt anything special just a stock mostly rb25, i gapped them to .08 and had sputtering all through boost, so i took them out and compared them to the plugs that were origannally in the car which were the bcpr6es but those were gapped at about .04 so im going to regapp them, if your having problems try lowering the gap. andrei said to gapp them to .028
