What Plug is this, and how can I make it work with my LS1 Swap?
wajouba
Car: Hyundai Tiburon Supercharged
What are these 2 called? and how can I find their pins and what each one is for?
Any specific swap thread that shows which wires we can integrate between this and the LS1 harness so I can finish up my LS1 swap?
Thanks
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Where dd it come from?
wajouba
it came from beside the battery in my 1992 Canadian 240sx S13
I took out all of my ls1 + 240sx harness, and this is the only part used to integrate the ls1 240sx harness, so now I fixed my ls1 harness and want to get them back together... I wanted to know if someone can help...
Thanks
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I idea man. I didn't use that. My LS ecu does not integrate with the body harnesses of the 240sx except for the fuel level signal, and tach signal, I kinda just kept those wires in there and used them.
wajouba
OutToWinPAHC wrote:I idea man. I didn't use that. My LS ecu does not integrate with the body harnesses of the 240sx except for the fuel level signal, and tach signal, I kinda just kept those wires in there and used them.
Thats wierd... cause what I found when I removed all my wiring... is that the integration is the following:
there are 3 red wires comming from the big gray connecter one is giving 12+ when I hook up the battery immidiately, and 2 are giving 12 when I turn my car on the ON position!
Other than that I faced a problem when I removed all my LS1 harness, which is:
On the dashboard you have the (brake light, battery light, etc) they all light up when I put my key on the ON position but when I go back to Off position they remain on!!! I wait a couple of mins then they turn off by themselves... is this normal? someone told me when you hook everything back this problem will be removed, but he is not that good in wiring so I can't trust his call...
Anyone?
marosvar87
Car: 90 Nissan 240sx
check out sr20det swap wiringthis might help you
http://www.frsport.com/SR20DET....html
