Darius wrote:The plug that you have there is definitely not for the injectors. I didn't look closely enough before replying. The injector plug has a gray wire like that one for the 12V supply, but the rest of the wires in the injector plug are white with a colored stripe or yellow for injector 5. I cannot find any plug on the RB25 wiring diagram that shows another plug like that one with similar colored wires. Are you sure it isn't part of your lower harness? or that it plugs into a female receptor under the fuse/relay box?
Is the lower harness considered the one that has the alternator power wire, the starter power wire, which lead to a split coming from the positive battery? This is exactly where this unknown plug is coming from... right at that split. I'm starting to think that this is just a plug from for something with the original Ka automatic transmission..
Thanks for the help, guys!! I'm just gonna ignore it, assuming that I won't need, because most of you have agreed that it is NOT required for the RB to run, therefore, should be irrelevant or not needed at this point.
