what pieces from a junked s13 is needed to add cruise crtl to mine?
lbrowne
If I found the parts around from 89-90 240sx's, what do I need to add a stock setup of cruise control to my base, BASE, baaaaaaaaaaaaaaaaaaaaaaaaaaaase model s13 coupe?
I know the fuse locations and etc are already marked for it...from what I seen I think.
thnx,
lbrowne
ps: i know i need the steering wheel, cruise control actuator er sumthin....
quiksilvia
Car: 95 s14 se
ill sell you the actuator (thing that moves the throttle right?) and the steering wheel,
lbrowne
what else would I need?
What year vehicle is this off of? Because I think I'm safe with my existing ecu...
darksyde
Car: my car
you got a second pair? and how much?
uhmm besides those two don't you need an on/off switch that's on the dash too?
darksyde
Car: my car
oh and don't you need like a speed sensor or a cruise control ecu?
lbrowne
I thought all the buttons for the cruise were in the cruise control....
180fan
Car: 89 fastback
if you want CC for your car, you'll need the small CC computer located near the ECU, the steering wheel that has the 3 buttons, the two buttons on the dash, the acutator, and the parts of the harness that run to each of those parts if I remember correctly.
lbrowne
Cool, so it should be fairly straith tforward if I got all the components..
Everything should just plug right in I would imagine.
darksyde
Car: my car
Quote »180fan if you want CC for your car, you'll need the small CC computer located near the ECU, the steering wheel that has the 3 buttons, the two buttons on the dash, the acutator, and the parts of the harness that run to each of those parts if I remember correctly. [/quote]
i thought so...i knew there were a few things missing here and there
Quote »lbrowne Cool, so it should be fairly straith tforward if I got all the components..[/quote]
as long as you can do some simple wiring and setting up the acutator...i'm pretty sure it can't be all that hard...just make sure u get the connector to everything...life will be 100 times easier :D
