BadMojo »
https://forums.nicoclub.com/badmojo-u5205.html
Mon Jan 26, 2004 1:43 pm
If you're sticking with stock springs, I'd recommend some KYB GR2 struts, at least one KYB strut mount and replacement KYB strut boots. Now, I don't know what the other side looks like, but if it were me, I'd probably replace both mounts and both struts, since the ones in your picture look they've been in there well past their prime.
With the amount of corrosion you've got there, I'd replace the two nuts and bolts down at the knuckle and the three nuts on the top of the strut tower. The GR2 shocks will come with the nut that goes on the top of the piston rod. Rent a macpherson strut spring compressor from Autozone (it's free) and you'll be all set.
I'd make sure of the integrity of the strut tower too. That *is* a lot of corrosion.
As C-Kwik said, those bearing fell right out of your decimated strut mount. That thing looks like utter ****!
