what parts do you guys use?
grantypanties218
Car: 95 q45
i need to replace my fuel pump and wondering what way to go replace it with an oem pump or a pump from napa
also where are youguys finding there fel pump control units? are these the same as a modulator?
OwnerCS
The best place (with the best price) to get parts is http://www.infinitipartsusa.com
Also known as IOS. Infiniti of Scottsdale.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I wish there was a good way to test used OEM fuel pumps with out them being on the vehicle. There is a resistance check but I wouldn't bet labor on a good OHM reading.
Either OEM new or OEM low millage used is best in my option.
I think I have to change my Fuel Pump on my car but I will do some pressure tests to be sure. I have a OEM new and used (137K miles) sitting.
I never thought I would need my spare wiper motor but low and behold I did and much sooner than I thought.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Welcome to Nico :bigthumb:
When mined failed, I also bought one from I.O.S. (Infiniti of Scottsdale):
The site isn't working right now, but here is the part number if you want to check out the price: 17042-60U00
tfitzs01
Car: 1990 Infiniti Q45
Definitely go OEM. At some of the prices NAPA charges, OEM would probably not be too far more expensive.
There are a number of threads already mentioning the Fuel Pump Control Unit. If it is not working, there is a potential fix that involves examining the harness and board. Saved me a bundle. Also do not confuse the harness examination with the EMERGNECY jumping of the unit. This will sacrifice the life of the pump from new to crap in a week or two.
grantypanties218
Car: 95 q45
thanks for all your help guys can anyone give me a link to that fpcu fix/solution
thank you
grant
Q451990
:welcome: to NICO!
Your best bet is to find a good used one. If you need one I should have a good spare around here somewhere. They usually go for about $50. If yours is suffering from a burnt lead on the board, you could jump over the burnt area with a wire. You can also replace the bad transistor looking components that are screwed to the side (as a heat sink) if those are melted. Those are the two failure modes that we see most often.
Heath
grantypanties218
Car: 95 q45
50 bucks for a spare fuel pump?
Infinitiguy19
$50 for a Fuel Pump Control Unit.
Q451990
Infinitiguy19 wrote:$50 for a Fuel Pump Control Unit.
Right.
I wouldn't recommend a used fuel pump as it's a wear item with an average life of only about 80K before fuel quality dropped so much a few years ago.... not sure what to expect now.
Heath
Infinitiguy19
Well as long as a heavy duty transistor is put into the Fuel Pump Control Unit and fuel pressure is checked every 6 months to a year I would say go for it. but with a brand new fuel pump all that fear could be taken away but it all depends on how much you want to spend on knowledge and money.
Is ISO-HEET still good to use?
