What part of the harness do i send off?
RobDET
Car: Cars
I got one outta the junk yard. What part do i send off? They cut it under the drivers side dash where it goes into the fuse box i guess.
RobDET
Car: Cars
RobDET
Car: Cars
RobDET
Car: Cars
SOrry they got outta order. the middle of the harness is last. I'm guessing all they need is the stuff in the first image all teh way to the connector in the center of the third image?
RobDET
Car: Cars
^^bump^^I'll only do it once but i need an answer
boost_boy
Send off the harness with the blue ECU connector attached to it. All the other stuff are already found in S13's.
spec-v5150
Is it even necessary to send the harnes to someone??? What does this service entail.....
boost_boy
If someone has a CA18DET and needed a harness, it would be wise to sell them that part of the harness as it fastens the CA18DET to it's computer to the donor car. I hope read and answered this correctly!
SpeedRacer1
Car: 1990 240SX, G35
spec-v5150 wrote:Is it even necessary to send the harnes to someone??? What does this service entail.....
Depends, S13 to S13 isnt too bad. S13>S14, S14>S14 or S14>S13 could be more difficult. And if you want AC to work then the wiring services might be able to help you out.
RobDET
Car: Cars
It's suposed to make it a plug and play affair as far as the harness is concerned. Enjuku however said that i would need to send them the harness all the way to the transmission sensors... Now my car is in the body shop or i could just look but which of those is the transmission plug? i'm assuming it comes off somewhere in the top pic?
SpeedRacer1
Those actually look like the main upper engine harness, but its really hard to tell from the picture.
RobDET
Car: Cars
that is all the wiring under the hood. It's cut on the side where it goes into the fuse box under the drivers side dash. in the first pic is the fuel injector harness to the ecu (top engine harness?) Second pic is the part that goes in the car and the fuse box that is under the factory air box. The third pic is the stuff in the middle (fuse box by battery, headlight harness, power wire exc. if it wasn't so heavy i'de just ship the whole thing to them
SpeedRacer1
Yeah, I meant that I doubt the transmission wiring is in the first pic up there.
RobDET
Car: Cars
OK. Does anyone know off hand how many wires and what color the transmission sensor plugs are?
