What part is this? 89 nissan pickup z24
cwo721
Car: 1989 Nissan 4 Cyl. Z24 Pickup
I have a 1989 NIssan 4 Cylinder Z24 pickup and I need to know the name of a part is making a sort of gurgling noise.
If you look at the picture in the link below it is the part that is directly in front of the window washer fluid reservoir. It's the circular shaped one, only about half of it is showing. I can't find a better picture of it online and can't figure out how to upload a picture off of my phone onto this message haha.
Any info on the part and what the gurgling sound means would be appreciated.
Thanks
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Are you referring to the black canister with the hoses?
cwo721
No actually the part in front of it seems to be making the noise.
Hopefully this picture works it is a close up of the part. It is the part that is the right in the middle of the picture.
https://drive.google.com/file/d/0B-rAKM ... sp=sharing
Midnight Tech
Car: 86.5 D21
84 Maxima
AIV box.Those things seem to attract moisture and eventually rust out.
cwo721
Thanks for the reply. Are these things tough/worth it to replace? Or should I just try to clean it out a bit?
Midnight Tech
Car: 86.5 D21
84 Maxima
Where do you live? If you're in a smog state, I'd at least try to get it cleaned up a bit so it'd pass visual inspection, unless the truck is exempt. Otherwise, I'd pull it.
cwo721
I'm in CA so I do have smog but don't have to do the test for a little over a year. I guess I'll just clean it out before I have to take it in next time. In the meantime, is it a big deal it is not in good shape? Does it have a impact on anything like mpgs?
I appreciate your help. As you can probably tell I am far from a car expert haha
