What part ## for the rear AC pipes?
A forum for the Nissan Quest... minivan lovers unite!
far raf
Car: 2005 Nissan Quest SE (standard? simple? edition - i.e. nothing special)
Lost the AC a few weeks ago.
This is from the fairly large leak right behind the passenger front wheel, under the front plastic clamp, where those hoses turn at a 45 degree angle towards the middle of the undercarriage. This spot got pinched a few years back, when I drove over a curbstone making a turn in a plaza with high curbs. It held up for about 6 years, and finally gave up with a loud hissing sound, draining the system in less than 1 hour completely.
The leak is in one of those long aluminum pipes which span the length of the undercarriage on the passenger side. I just could not determine what parts those are, as there seem to be 2 long straight pipes, and one which has a loop. How can I find out which one leaked, without taking everything apart? All 4 under the same clamp. In what order do those parts appear under the clamp?
MidwayParts
Vendor
Car: 2011 Titan
Looks like you need part number 92460-ZE60A $266.94
It includes all 4 pipes. Nissan only has 4 available. If you have any questions let me know.
Mike Jones
[email protected]
partsfornissans.com
far raf
Great, thanks, Mike, now I understand! It was not a loop, it was a connection to the AC. Buying the whole set including heater pipes sounds like a huge waste of money.
So I need 1 piece of 22117N bracket and most likely the low pressure pipe which has no part number and runs along the high pressure 92463L, plus 2x of 27644P O-rings.
Sounds like the low pressure pipe is a generic pipe fit to shape and flared in the shop, as it has no part number and says "Not serviceable". Is that right?
MidwayParts
Vendor
Car: 2011 Titan
BRACKET 92482-5Z000 $4.29
ORINGS 92473-N823A $1.08 EACH
Yeah it is not serviceable from Nissan. They make you buy the whole tubing assembly. Figures its the piece you need.
Mike
Return to “Quest Forum”
