I searched already and after 15 minutes of dead-ends, I though I would post.I have removed the power steering from my 95 KA24DE. The problem is that the power steering was used to tension the belt that goes around the water pump. I figured out a way to install the water pump belt around the crank and not use a tensioner, but this requires a belt of very specific length. The problem is that I cannot find a belt of the exact length I neeed.
Sooooo, are there any other water pump pulleys, OEM or aftermarket that bolt on the KA water pump? such as from an SR or RB? I dont car if they are bigger or smaller than the OEM KA pulley, I just need to find something that bolts on with the same offset. thanks!
