What oil would you recommend???
Crazyracer77
i just bought a 89 240, im going to change the oil in it tomorrow, i was just wondering what you all thought would be the better oil ro run, it has 175xxx on it, runs really good, it has a slight oil leak, maybe from the front crake seal, the engine is bone stock, i was thinking about running 10 40 in it. im not sure, any suggestions would be apreciated
Thanks
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Mobil 1 or Royal Purple, 10w40 or 5w40 is what I use, a tad expensive but always makes my engine feel fresh.
Supposedly Castrol GTX is good but i dont have experience with it.
240DRFT
you probably wouldnt want to run synthetic, it'd cause more of a leak than what u already have
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
240DRFT wrote:you probably wouldnt want to run synthetic, it'd cause more of a leak than what u already have
Not always, if you use a heavier weight it will actually prevent/stop leaks
I personally use Mobil 1 15W-50 but that’s because I live in cali and its always very hot
Crazyracer77
for summer go Mobil 1 15W-50 or 10W-40 for winter 5W-30 or 5W-40
TheOne
Car: 93 240sx FB
10W-40(or 30) should be good.
Crazyracer77
i guess ill try the mobil 1 10 40 and see how it works...
sanioll
Car: Nissan 240SX SE
Toyota Camry
I dont think Mobil 1 comes in 10w-40 weights.
i use mobil 1 0w-40, thanks to palmerwmd's advise, it is great.
jmhalder
Car: base model 95 S14, steeliez, boosted on the T25, going to HY-35, and 650's/N60/walbro/bikirom to han
well, nissan calls for 10w-30. so get your butt out to walmart and buy a jug of mobile-1 10w30
PalmerWMD
Car: 2004 350Z
Go a bit thicker cuz syummer+ hih miless needs thciker oil by at least one notch.
SO 10w-30 recommended = 10w-40.
since you leak no sense usung expensive oil The <best> inexpensive oil for your applciation is Chevron Supreme 10w-40 .$1.50 /qt at walmart(or if not on budget Mobil1 0w-40)
Fred..
240marcuSX
Car: E34 525i
E46 M3
i use castrol GTX and like it just fine.
bruinbear714
I recommend AMSOIL 20W-50. Best oil you can feed your car.
kenversusryu
actually, running synthetic on older engines (especially one that is leaking) may not be a great idea. Synthetics are slipperier than dino oil so they can run through rings and cause all sorts of leakage.
here is a good explanation of synthetic vs dino oil by a NASA engineer.http://forums.yellowworld.org/....html
Here is a good explanation on oil grades.http://my.prostreetonline.com/...id=18
