2mhighside wrote:Hey Joe i know its off topic but i was wondering about your Sub box. Did you build it yourself? Iv got a set of 10'' MTX subs and a 350 Watt amp ive been wanting to install but really havent been impressed with any of the sub boxes ive seen. Do you still have plans on yours? Also what kind of a job is it to pull signal off the back deck speakers to run to my amp. I know Bose runs different Ohmage whats the deal with that?
Sorry, I don't have plans for the box...I had it custom built. It shouldn't be that difficult to build though. The amp is where the spare tire was, under Plexiglas. For the amp input signal, the rear seat "sub" are used. As long as the amp can accept high-level (speaker) inputs it will work. The bose speakers run 2 ohm speakers, but the amp is just a normal amp. It isn't too hard to disconnect the speakers, solder wire leads to your amp location.
There are other options...A few companies make a stock stereo deck interface that provides 5 volt preamp inputs. They level out the curve of the deck.
