what OIl...
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
I was just curious what kind of oil everyone uses...10w-40/ synthetic? mineral....??? brands.....
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
I use 10w60 Castrol or 15w50 Mobil 1, both synthetic.
/Mike
Edit: I mean summer oil.
Modified by Swedish Mike at 2:17 PM 5/25/2006
float_6969
Winter:M1 0-40W;Change every 5K milesSummer:M1 20-50w;Change every 10K miles(Both fully Syn)Running a Purolator PureONE oil filter, changed every 3K miles.
Kouks
I bought Royal Purple 10w-40 thinking it was the correct one. Anyone else use something different..Why 20w-50?
I know what it means but why is it necessary to have such thick oil....
rico05
Car: 1992 RMS13 w/ CA18DET
I run Mobil1 15W-50 summer and winter. i just let her warm up extra in the cold months (no thermostat on my oil cooler setup).
1via
I run 10w40 royal purple. I like but its expensive.
float_6969
I've heard/read in multiple places that 40W is the minimum hot rating you want to use for a turbo motor. My car is running and sounding better than it EVER has with the 20-50W that I'm running right now.
Zero260
Car: 91 240sx coupe
high viscocity oils don't flow as fast, so in a turbo set-up, there can be some problems with insufficient oil flow, but with synthetic oils, they're thinner anyway. 20w50 syn will protect like a 20W50 but have better flow characteristics, so just use syn. if you're gonna run 20W50.
on another note, if you run a thinner oil, technically you will produce more HP, but it's a small amount.
