Dtoys S14 »
https://forums.nicoclub.com/dtoys-s14-u14353.html
Fri Apr 11, 2008 9:25 am
thanks for all the advice , since we've got the car delivered from colorado the previous owner went mia , but i called procharger and they told me to use whatever the car uses stock 5w30 , 5 quarts and the charger has its seperate oil in it , so i have to buy oil from procharger and change the oil on the charger , also while in the process of changing the oil i notice the car has an AAM (altered athmoshpere) oil spacer on it , so i contacted them and i had to put an extra quart for the spacer , so if u are running a spacer from aam use 6 quarts of oil , and if u are using a procharger supercharger u have to change the oil on the turbine housing itself and also use there special oil in the charger , they wouldn't give me any substitute oil product from a local store !
VERY IMPORTANT , after everything is done and u've checked for leaks and the oil level make sure and put the clip back on the dip stick , i kinda forgot and the dipstick backed out and oil spurted everywhere , dont make the same mistake i did !
Damian
