What oil should I use to run it in? And what intervals between changes etc? The block specs are as follows:
-acid dipped ca18det block torque plate bored to .5 oversize
-4port head fully rebuilt with mild cams, adjustable cam gears and blue gates race belt.
-Tomei 1.5mm MLS headgasket & ARP headstud kit
-custom CP pistons
-spool 700hp forged chromolly HBEAM rods and ARP bolts
-ACL race bearings
-Fully preped, grubscrewed, balanced crank.
-genuine oilpump
