Densetsu »
https://forums.nicoclub.com/densetsu-u91979.html
Fri Aug 08, 2008 6:28 am
Either 5W30 or 10W30 is fine, dino or synthetic. If you anticipate you're going to drive somewhere below freezing on this oil change, go with 5W30. If you're staying in CA, either is good.
Switch to 10W40 dino oil if the Pathy has been leaking oil, it might help a bit. Otherwise stick to the weights above.
