What oil are you running?
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
I'm thinking about running Max Life in mine... even though the motor is "low mileage" it is still ~12 years old with old seals.
I've been reading something like 10w50's the way to go regardless of which style of oil you run.
Let me know what you're running!
PalmerWMD
Car: 2004 350Z
I "only" drive an SR, but based on the fact its summer >and< you have a turbo a synthetic 50 weight is my recommendation.I run M1 15w-50 in my SR.
Im hope you wont consider the following a hijack:
There is evidence that using thin oils like any xw-30 will harm your turbo charger and possibly the engine as wel,l if run at boost.
Also Synthetic oil has a much superior resistance to oxdiation than a dino oil, which is the single most important feature an oil in a turbo engine should have.
Dino oils are ok only, if you use the toughest of them like a 50 weight performance oil, but even then I would strongly prefer a syn.Some of the better synthetic 40 weights would make an good winter fill on a turbo ( Redline 5w-40)
Fred..:)
rbsileighty
Great info... thanks Fred!
frosted flakes
i run 20w-50 valvoline vr1 racing oil (non-synthetic)
I had mobil 1 10w-30 synthetic oil and it was wayyy to thin...the oil would just go through the bearings in the turbo charger and shoot out into the intake tract..it left me with a film of oil in the intercooler piping and intercooler...and it smoked white smoke really bad out of my exhaust when i got on it. NEVER USE MOBIL1 10w-30 synthetic with rb20det...its simply too thin.
after i switched to 20w-50 valvoline vr1 racing oil it no longer smoked. its a thicker oil so its better for the summer...i would probably use 15w-50 in the winter...
Tony
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
hmmm I have mobile one synthetic in my rb25det and it doesn't smoke at all. All the pipes are clean. I am still going to be switching soon, because I do agree that is to thin of an oil.
xjon
Car: 99XJ, 93 240coupe
Mobil 1 15w-50 $21 5 qts @ Walmart
DETurbine
Car: Nissan S13 RB25
Mobil 1 10w-30 full synthetic
SillyRB
In my Sr DET's i used to ise 10 - 40w (NOT FULL SYNTHETIC) NOT good for the turbo
On the RB25 I use 10 - 40 again...it runs good
A motor w more milage should use oil that is slightly thicker....
Joe
why isnt synthetic good for the turbo? it lubricates the same (better actually) and has a higher heat resistance. the only difference between most synthetics and dino oils, is the dino's have addatives like seal swellers. thats why when alot of people switch from dino to a full syn, they have leaks.
and the thicker oil thing isnt really true anymore, you should only run what the manufacturer reccomends. at 0 miles to 500,000 and beyond. it was a rule of thumb for older cars but not on late model cars because parts dont wear out like they used to (better engineering and machining techniques.)
I run 10-30 mobil 1 full synthetic. as close to the reccomended 7.5W-30 nissan reccomends.
frosted flakes
all i know is when i switched to mobil 1 10w-30 fully synthetic it started smoking really bad...i looked at my i/c piping and oil was everywhere...maybe since my motor ran on regular oil it didnt like the change to synthetic...
after i switched to 20w-50 valvoline it ran MUCH better with no more smoke...
i dont think that synthetic is bad, but if your engine ran with regular oil stick with regular, if it ran with synthetic use synthetic...
