What offset wheels, WILL and WONT clear Megan Racing Coilovers?
daconkiftador
Car: '92 Coupe SE, '83 Rabbit GTi, '91 Golf GTi
any got some real info on what offsets will and wont clear Megan Racing Coilovers?
onosqv
Car: '92 240sx Vert
this has been discussed a billion times. these coilovers are about the same as other coilover clearances. You can also ask Megan Racing themselves (although their customer support is below average).
as a starting point (highest offset you should go) -
front: x8 +30rear: x9 +35 or so, maybe even get away w/ x9.5 +35
You can adjust your width/offset accordingly w/ available wheel offset calculator.
The tires you can run may differ a bit - possibly have to run stretched tires.
As a reference for you. I'm running x9 +20 all around on 225/40 tires and they clear my kts coilovers just barely in the front, plenty of room in the rear.
Red coupe
Car: 92 Nissan 240sx Coupe
stock wheels clear KTS
