What Offset to bring rims out to Fender?
TheCandyManS13
Car: 1991 Nissan 240SX
Hello, I'm new to the forum and relatively new to the automotive scene in general.
I'm looking at purchasing some Diamond Racing Wheels for my AutoX 240 (as seen below - craptastical!!)
I'd like for the rims to come out to be flush with the fender, I'm looking at
15x8 in the Rear and 15x7 in the Front
I read somewhere that +20 would reach out to the fenders on 17x9s, but I can't really make a relation from 9 wide to 8/7 wide. Thanks in advance!
AZ89two4Tsx
17x9 +20 will stick out unless you run some camber.
For an 8" wide wheel, +15 is REALLY close to flush. If you want to be baller, get +0.
TheCandyManS13
Thanks guy, the help is greatly appreciated
AZ89two4Tsx
Oh yeah, look here too.
zer...age=1
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
I have 16x8 +15 offset and my fronts will actually stick out about 1/2 inch with a 205/55 on it, thats a slight stretch so if you square them up they will prolly be way more than that, but more camber can solve that. as for the rear i have no idea since im running 30mm overs with a 25mm spacer....actually might only be a 20mm cant remember
