What odor come inside car when full kickdown?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
CHi.tA.kE
Car: C11 white 1.8 H/B M/C 2010
I'm got new V-1.8HB but I'm found some oder (smell) moment when full kickdown only, what's odor & how fix this problem or normally of new car?Thank for any reply & recommened.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
When you say "full kickdown" do you mean you push the accelerator to the floor for maximum acceleration?
I don't have any odors. Does it smell sweet, bitter, etc.? Can you describe the odor?
CHi.tA.kE
[/QUOTE]
Promise Land wrote:When you say "full kickdown" do you mean you push the accelerator to the floor for maximum acceleration?
Yes, i mean the maximum acceleration & smell like sweet with some burn out of something a little too.I'm not sure may this probelm what's relate to AT transmit when high torque load immedately after push accelerator to the floor?
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
If it smells sweet, then it is most likely antifreeze. Do you see any green fluid under the car after it sits overnight? The odor may disappear after you have some kilometers on the car, but if it persists I'd suggest giving the car a good wash (outside, under side, and engine). That may help clean extra fluid from the exjaust, which may be why you smell a sweet odor.
I have an automatic transmission also.
CHi.tA.kE
Many thank so will try........
nissantech171
Car: 07 sl versa
if the odor smells like rotten eggs or a stinky fart its normal anyways lol. Catalytic converters are suppose to convert your exhaust to carbon dioxide water and nitrogen. and you do get excessive hydrogen sulfide production while at wide open throttle also the fuel you use may have higher concentration. also at work i do find nissans run a little on the richer side which causes the odour
Return to “Versa Technical Discussions”
