masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Fri Jan 21, 2005 8:41 am
I think that the additives you speak of are more built around the brand of gas you buy, not the octane rating. All gas companies get their gas from the same sources, and add their own stuff later.
People talk about 91 octane like its battery acid, and then talk about spiking their tank with toulene. If you run a pretty stock 240sx, you don't NEED anything better. It's not like the KA is inherently a tightly-wound performance engine.
GuSpeed, you say you have an Injen intake and some catback? Okay, well, here's a couple other questions...
Do you wait until redline before you shift? In that case, higher octane is good.
Do you notice pinging or knocking, or does your CEL come on regularly? In that case, along with a few other changes you need to make, switch to higher octane.
If your car runs fine on 87, there's really no reason to change it. I ran 87 for the first year and a half that I owned my car, and I run an Injen intake and Hotshot headers. You should have no problem.
Note: I run 91 now because the motor just clicked over 224000 miles. I probably didn't NEED to, but I drive less often now, and can afford the extra 20 cents/gallon.
