NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu Apr 29, 2004 7:28 pm
since this seems to be happening cold it could be a couple things. They are right on it about how the gas got in your oil the car is flooding and the fuel is by passing the rings into the oil. This is called washing down the cyl's. This does not mean the rings are bad. This means you have an excessive fuel condition. Start by changing your oil and filter, take the plugs out and clean them off or replace them with quality NGK's [link in my sig to find the right ones] after this is done hold your pedal to the floor and crank it till it trys to start,this will help clear the fuel built up in the intake and cyl. Once it starts to fire up start leting off the throttle til it actually fires up then come down to hold it at 200 rpm for about 20 sec's this will help it clear the fuel to the point of normal fuel intake.
Your possible problem are coolant temp sensor or as ckwik said bad oring at the base of the injector or even a dirty injector pintel. check your 2 wire coolant temp conector for corrosion clean as nessesary, also locate the procedure for setting base idle on your car and check to make sure thats right. To check to see if its an injector you need a fuel gauge to check for pressure loss after the pump pressurizes the system. this is done without the car running. You simply cycle the key to on and let the pressure build till it stops then watch it if it drops more then 10 lbs within 5 to 10 mins you have a fuel pressure loss somewhere in the system. it should hold pressure even when the pump shuts off. considering your problem it would likely be something with the injectors,either orings or internal injector problem[pintel stuck open]
