what not to do when cleaning calipers
Dr.Fate
What I don't I do when claening the calipers?and is it the same with painting them? and while I'm at it do I need back 300zx brakes if I have the front? I have the F/R sets of brakes, BMC, the whole rear assembly and ebrake aswell.
TrunkMonkey
Car: 2000 Lincoln Navigator
what?!
-demetrius
BMAR240SX
Car: 1993 Nissan 240S Coupe
TrunkMonkey wrote:what?!
-demetrius
Zhanshi
Uhh, Im gonna assume this is 3 seperate questions...
For cleaning, just use brake cleaner and a toothbrush. Spray and scrub.
For painting, clean first and mask off parts you dont want paint to get on (brake lines, pads, rotor, etc).
As for the conversion, there are a couple stickies that have covered this. You dont need the rears per say, but it will alter the braking bias.
FalkenDrift
Car: 1989 s13, 1992 s13 sil80,
dont clean them while the cars running.
Thaddeus
Car: 1998 240SX se 1984 Porsche 944
If the calipers are off the car it would be a good idea to get a C clamp and push the pistons in before you paint. This will save you from potentialy ruining your paint job when you install.
