HAHHAHAH...so trueCraving4Boost wrote:damn i should post up a thread "What negative things can happen to a Turbo'd guys LIFE!" no clothes...im starving...im growing white hair from workin so hard...dont go out with friends much anymore...annddd im 18 years lol....boost bby..gotta love it
It really is....lollilskyline240 wrote:
HAHHAHAH...so true
Question: negative things can happen to a turbo'd engine?mr_wizard wrote:As long as one keeps its lubes cared for on a regular basis I think it would be ok right? Or do the rods and such tend to bend? My engine is healthy, but has alot of miles. 170k actually, but has awesome compression. Should I turbo?
??? How does timing ever cause an engine to run lean? Advancing timing only increases cylinder pressure and heat. Which leads to detonation. Running lean can also cause a hotter combustion, which can cause detonation. But timing does not affect the A/F ratio. That is purely a function of air being sucked in and fuel being squirted by the injectors...Jookmasta wrote:so to answer ur question, timing. timing can be advanced to where u run to lean, engine knocks, and boom. the key is tuning. no way around it. if ur compression is solid and the other engine things are working fine, go for it. the car has to be tuned properly for it to last as long as possible.
Learn the rules of spelling; grammar and sentence structure wouldn't hurt either.180sx wrote: i wonder learn rules of combastion .
Huh? Your post makes zero sense. But based on what I could barely interpret(the first sentence)... I'm gonna say you're wrong180sx wrote:u crazy man!!! timing won't affect a/f fcuk yah it does
more advanced timing as u sad makes more pressure and hotter what does that mean ??? i wonder learn rules of combastion . how u think they tune cars crank up timing increase fuel . and thus retardint timing takes away power and decreases fuel needed . add fuel and timing retards becouse too much fuel takes longer to ignite . thats why if u get to fire at 0 degree when piston squizes all that air to max and u have fuel at lambda u get max power.
same with spark the more advanced timing gets und more compressed air gets bigger spark needed to create explosion
I speak 3 languages actually; English, Polish, and French. However, I am not going to get in a pissing match with you.180sx wrote: 1 titan is this english 101 or ka-t forum ? by the way english is my 4th language and i am still learning as you can seeand have been for past 3years , how many languages u speak before u gonna ***** about my grammer
Readings are one thing. But the actual air/fuel does not get affected. And not to the extent you might think. You'ld actually need a 4 gas analyzer to detect the changes in exhaust gas content to see the total effects of timing changes.nissanfanatic wrote:Timing can affect Air/Fuel ratio readings.
There will actually be plenty of time for the mixture to burn. In fact too much retard will cause some of the mixture to burn in the exhaust system. Depending on where in the exhaust stream the measurement is taken, it may give inaccurate measurements of the actual A/F. The A/F ratio is the actual air to fuel ratio. Getting inaccurate readings due to conditions has nothing to do with what the actual A/F ratios are.nissanfanatic wrote:Much of the combustion process relies on heat created by pressure. Boost+CR makes the heat necessary to burn fuel rapidly. Namely why higher octane fuel is needed for higher boost/higher CR engines. If timing is retarded too far, PCP will occur past optimal crankshaft degree thus not creating enough heat to completely burn the charge provided. Hence power loss. This means there is oxygen left over from combustion. Now how does a wideband work? It detects oxygen in the exhaust stream. So, too much retard and you will get lean readings. As you advance, you may start to see Richer readings as less oxygen will be present due to it being used.
Misfires are an entirely different beast altogether. Keep in mind the context of the post that sparked this. He had said the motor would run lean and detonate. Even if the timing caused the A/F reading on a meter to show lean, the actual A/F would be independent of the timing. The motor is still geting the same amount of fuel and air.nissanfanatic wrote:Also, misfires will show up as lean readings as well. So, for any of you that see "LEAN" when you get hesitation or hit that "brick wall", automatically check ignition system. Misfire means that most-if-not-all of the charge was dumped right out. What happens? Wideband picks up a shat-load of straight air. So you get a "LEAN" reading.
