Wow you have been here longer than him. That matters exactly how? Since it somehow matters to you, count my time, subtract your time and adjust your attitude. Since you have been here so long salty dog you should be very adept at the search function Your question is so stunningly basic it has I am sure been covered ad nauseum in previous threads.I don't want you to be hard on the "new guy" though so I will answer your question. The RB20 has no mechanical weakness to address like the SR20. If the motor is tight, not "tyte", "tight" as in good condition it will give you no trouble at all. It has a timing belt so be sure that is reasonably fresh as you will be spiking the revs up and down and do your maintenance. The only thing worth mentioning about the RB20 is it runs very hot so make sure the radiator is capable and the water jacket is not all scaled up with rust from poor maintenance. That falls under being in "good condition" though. Replace all the water hoses under the manifold and the water neck in the block, they need it without exception.ViperSRT10 wrote:I have one word for youREAD
I looked at those. All they say is what you need to swap in an RB. I have also searched. I am looking for what you need to do to them to make them dependable at the track.
For instance if you have an SR, check the oil pan for dents and it will be good to get a new one, or rocker arm stoppers.
Information like that.
So please read the post before thinking YAY I get to look kool and tell someone who has been here longer than me how to use a forum!
Interesting.. I thought that the oil pump was the achellis heel of the RB2x. Maybe it is just 25/26??themadscientist wrote:Strangely I have never seen a 20 pop an oil pump but I know of several 26s and it definitely is a weak spot. Maybe 20s just don't tax the pump that much or a head gasket goes first or something. Very strange.
Where is this water jacket you speak of? I want to check mine since the engine is out of the car. Also, where is the water neck and how do I access it to check it? I think I can handle replacing the hoses. Sorry for the stupid/simple questions, I just dont know the answersthemadscientist wrote:
HUH????!!!!! You don't need to rebuild a whole engine for it to be reliable! Stock will be more then enough if you replace all common problems. And for any RB you'll spend more then 5g including motor. That I can almost guarantee you.S13 240SX wrote:I have an rb20det, spent 2,500 dollars already and it drove for 4 days out of the whole summer of this year i have had it swapped in. and mostly likey it's never really dependable intill you rebuild the whole engine.
The water neck is where the thermostat sits, when you pull the thermostat(you replaced it right?) you can see if it's rusty in there. There are methods of "descaling" water passages, you'll have to research them and and one that you're comfortable with.AxiOn419 wrote:
As you know it has a larger bore than stroke and that is the beauty of it's ability to redline so easily, it's an oversquare design. Although that also contributes to a small extent it's tendency to overheat (not greatly though)I'd be willing to bet with a set of good aftermarket rods and bolts, upgraded oil pump you could rev the RB20 to 12K with proper oil restrictions in the head, maybe some head porting to support upper RPM flow and a good tune.themadscientist wrote:well the 20 is single turbo, maybe the head has more restrictive passages, perhaps it has less of a demand for oil? I know most RB20 guys are pegging them off the tachs needle stop a lot so it must be something. Shorter stroke, smaller bore, that must be less strenuous than the bigger motor at the same RPM. An larger piston swinging up to TDC on a longer stroke and changing direction has to impart more stress on the oil film. Just spitballing, I am not sure that would be the cause.
Thanks! I flushed that area with a hose for a good 5 minutes. Now if only I could find that water jacket..uber95 wrote:
Is that practical to do and is it worth doing? The engine is out of the carCarl H wrote:the water jacket surrounds the piston bores...no real way to access it unless you knock out all the freeze plugs and wash it out that way.
I wish.. At this point I know how to do basic engine maintenance but am in the process of learning more since I am doing this swap with a friend of mine. Got to start somewhere!themadscientist wrote:Oh snap, I thought you were joking!
