What needs to be changed on engine that hasn't run in years.
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
I bought an SR20 Clip, and I have no Idea how long the clip has been sitting. I thought it would be a good idea to take it apart and replace all the seals, gaskets and what not, so there will be no question to the reliability of the motor when I put it in. I am just curious on peoples thoughts on this.
So far this is what I plan to replace:
Water PumpThermostatAll Engine GasketsAll Expansion PlugsValve sealsFront and Rear SealsPiston RingsSpark PlugsFuel/Air/Oil FiltersInjector Seals
Is there anything else that should be replaced or checked while I am in the motor?
180fan
Car: 89 fastback
bearings for the crank and rods, depending on how clogged it got, possibly the oil squirters, possibly rocker arms as they've got oil squirters on them as well
2_Liter_Turbo
How would I test to see if the oil squirters are clogged?
Nismo_Freak
Car: 89 Nissan 240SX
You can't test the block ones without taking the whole motor apart.
You can test the camshaft oilers by just turning the motor over w/o the valve cover on.
