the503girl »
https://forums.nicoclub.com/the503girl-u59621.html
Wed Mar 14, 2007 1:09 am
Ok I drive a 1990 2+2 300ZX non-turbo automatic, it has about 168k miles on it and I just recently bought it about a month ago. I was told that it was leaking oil but they didn't know from where, so I took my car in today to have an oil change and a safety check to see what else is wrong with my car because my car isn't as fast and accelerating as good as it should be. (I already ran codes on my car and came up with 55 which means nothing is wrong). Anyways I'm going to tell you exactly word for word what my mechanic said and I need to know what you all think of it, like how much parts would cost and how serious the problem is, etc. I have a friend who knows how to work on 300ZX's that would do it for dirt cheap for me so I just need to know what you all think about the problems, how much the parts would cost (estimate), how hard of work it would be to do, how serious the problems are, what will happen if nothing is done and so on. anyways here is exactly what my mechanic said:
TECH'S NOTES:During the test drive the oil pressure gauge would not read about 20 psi and reads only just above 0 psi at idle. During the vehicle inspection I foundthat the engine and the accessories are covered in oil. I ran the engine at idle and hoisted the vehicle to inspect for immediate oil losses from the oil pressure sending unit but found none. The majority of the leak seems to be coming from the timing cover seal, which is in fron of the enging oil pump. Also the valve cover gaskets are leaking. Recommend replacing the timing cover gasket and seal, the valve cover gaskets and the oil pan gasket. The oil soaked engine mounts would need to be replaced as well as the oil contaminated drive belts. Also recommend replacing the oil pump to complete the repair. He also noted the exhaust collector gaskets behind the ctalytic converters are leaking. Recommend replacing gaskets.
So please please please people let me know what you think about all this and please answer my questions about the work that needs to be done,etc. Any advice and or input is welcome! Thank you in advance!
