what motor should i use in my 95 SE-R ?
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
stanthes13man
Car: ASK ME FOR PARTS !
hey guys i picked up a 95 se-r with a blown motor, my question is if i can use a JDM SR20DE from a 90-94 or 95-99. i know about the low/high port, i just want to know if i can use the 90-94 without having to do modifications. thanx
nametakennow
Car: '06 MINI Cooper S
The ECU and wiring harness are different b/w 90-94 and 95, so you'd need to get a USDM 90-94 harness.
It'd be simpler with a 95+ motor, but yes, you can use a 90-94.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You can use the highport motor, 91-94. We put a highport motor in a p10 g20 that originally came with a lowport motor. You only need to extend the knock sensor wire. Everything else plugs up just as it would normally.
stanthes13man
thanx guys, im on my way out the door in a few min to pick up the motor.
nametakennow
I didn't realize it was that simple. I'm surprised.
Yay for Nissan not complicating a good formula.
Ceasar
Car: 97 Nissan Maxima SE
could you get a vq30de-k to work ? (2000-2001 nissan maxima)
RED_DET
Vendor
2011 Infiniti G37x
you can get it to work in a b15 chasis.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
