i use RTV on all the things you just mentioned.StryfeS13 wrote:Im talking about little paper thin gaskets like the water pump gasket, thermostat housing gasket, oil pan cork gasket, etc.
Do you guys just use ultra grey rtv on both sides, let it tack up, the install? OR do you use gasket glue and glue the gasket to one side, then use rtv on the otherside?
example, glue gasket to water pump, put bead of liquid gasket on engine water pump housing, then install?
Or do you just install them dry?!
what about the valve cover gasket?? it has the groove but uses a rubber gasket seal. with some rtv on the head under the grovvets.martins_240sx wrote:if there is a groove cut into the matting surface it is intended for rtv. if it is flat matting surface then it was originally intended for a gasket...
RTV is on everything except the RMS and FMS those go on dry, the valve cover gasket is a rubber one also dry,StryfeS13 wrote:It's not cork, my mistake.
I believe it is rubber. It smells like rubber lol, and it's a little stretchy.
@ napoleon - you just use rtv instead of gaskets? What about where the rear main seal housing bolts to the motor? hope you know what I'm talking about.
